-   -   Cig interior guys (https://www.offshoreonly.com/forums/cigarette/382483-cig-interior-guys.html)
F-2 Speedy 05-15-2024 02:51 PM
Cig interior guys
So whats the trick to getting to the top mounting stud the nut came off, the 5 inch tube that carries all the wires and cables is just underneath it
TIA Speedyhttps://cimg1.ibsrv.net/gimg/www.off...89375eb7fb.jpg
88bullet 05-15-2024 09:55 PM
cant reach in from the engine bay?
F-2 Speedy 05-15-2024 10:06 PM
Id have to remove the back seat
cigrocket 05-16-2024 06:16 AM
I took ratcheting box wrench, a piece of aluminum length, secured the 2 together with some hose clamps and bent it enough to get in the hole and used it as an extension.
F-2 Speedy 05-16-2024 09:29 AM
I took the the handle off then removed the lower stud, pulled the lower panel out far enough to get a lock washer and nut on the top stud, then reinstalled the lower stud in the handle, Im going to try your ratchet wrench extension thingy to tighten the top nut.
F-2 Speedy 05-23-2024 06:31 PM
Right you are Sir........worked like a champ..........:drink:
https://cimg3.ibsrv.net/gimg/www.off...464d77e08a.jpg
bajaman 05-24-2024 06:44 AM
Now how do you get the nut back ON?
F-2 Speedy 05-24-2024 09:42 AM
its all done, I got the washer and nut on by going in between the two panels before installing the bottom stud and nut.........what a PITA
