89 Top Gun holding tank???
I`ve got an 89 Top Gun and the head holding tank was removed some time ago. Where was the holding tank located????
Thanks, Kurt. |
I have an '89 and '88 Bullet. The tank is located in the head under the sink. If you remove the storage compartment next to the sink you should see a platform and evidence of where it was mounted. Several years ago I replaced mine from the original manufacturer located in southern Florida. I found that out because they have a tag affixed to the tank. If you want I'll remove my storage compartment and get you the phone#. Let me know.
In my 93 Top Gun, the tank is just aft of the throne. Remove the hinged hatch and liner, the pumps and tank are under. Not a fun place to work.
Re: 89 Top Gun holding tank???
Originally posted by Biggus I`ve got an 89 Top Gun and the head holding tank was removed some time ago. Where was the holding tank located???? Thanks, Kurt. I have a 1989 Top Gun also as you know. The holding tank is located under the "floor" of the first cabinet on your right as you enter the cabin. I swaped mine for a stainless unit 2 years ago. Here is another problem how do you change the water tank ? Hope this helps Cigaretteman |
Thanks for the info guys!!!!
by the time i`m through with this project I`ll be #1 in the #2 business!!!:D
I have an 87 and it was located under the floor of the starboard side locker. I took it out and put in a porta potty, no one would even fit in the little bathroom.
| All times are GMT -5. The time now is 11:38 PM. |
