Performance expectations with new engines
Anyone have a good idea of what I can expect performance/speed-wise from my '85 35' Cigarette Mistress with 600hp@5500rpm, 675ft lbs @ 3500 rpm T-540's with TRS drives and weighing in at ~8500#? I know there are other similar Cigarette's out there with similar setups.
The boat was originally equipped with 330hp 454's and was good for 60-62mph. The speed predictor at go-fast.com says 80-82 mph with 1100 combined hp and 8500#, but I think that is probably overly optimistic. I'm not looking for the highest top speed possible, just overall respectable performance. 75 mph would be nice though. TIA. |
Monty,
Remember that the speed calculator at Go Fast is based on Prop shaft HP not crankshaft. For example a Merc 500HP has 470 at the prop. That calculator has always been pretty accurate when all the information is fed in. Good Luck. |
Also are you positive about your wheight #8400 seems light for a 1985 35' Cig mine is a '94 and is #9400 Dry.
GLH,
That's a good point about crank vs. prop hp. My 540's should make 590-600hp, so I used 1100 combined as the hp input, figuring a drivetrain loss. I based this drivetrain loss on my automotive experience knowing that automatic transmissions and drivetrains generally lose around 15%. But that's with a 4 speed automatic tranny, driveshaft, differential, and rear end. I figured that was a conservative drive loss. Maybe I'm wrong, but I would have thought the loss would be less on the boat as a result of the much simpler drivetrain( 1:1 Velvetdrive's w/ TRS) compared to a car. I could also be wrong about the weight, but I was told 8500# was about what it weighed. |
Re: Performance expectations with new engines
my mistress is closer to 10,500. i'm ready to freshen or repower this winter. the engines are already out & stripped.i'm considering 540's anyone want to gues about top speed???
trs drives |
You may want to get in touch with "Stalkin" (James) from the boards. He just sold his Mistress and replaced it with a sweet T/S Tiger. But he'd have all the info you'd want since he built the motors in his Mistress I believe. He lurks every once and a while on here but just PM him, he's approachable and a super cool guy.
Tank |
74-75
It's probably a kevlar boat, do you have a picture of it inthe water? Wasn't this Fred's old boat? I'm sure he would know. We had a Kevlar Mistress w/330s ran about 62. With 500hp it ran 70mph.
LS JR. |
LS JR. |
My 1977 Mistress has twin 650 hr with trs 71 at 5500 using 24 hydromotive.
| All times are GMT -5. The time now is 07:23 AM. |
