-   -   bullet hatch (https://www.offshoreonly.com/forums/cigarette/73505-bullet-hatch.html)
riski bidness 03-08-2004 07:46 AM
bullet hatch
anybody know where i can find the two small hatch cylinders for a 1988 bullet that lifts up to go into the cabin
OldSchool 03-08-2004 08:32 AM
Cal Tres @ Martin Marine. I need to call him as well. I'm sure that he has them!
Craig
riski bidness 03-08-2004 12:52 PM
bullet hatch
thanks craig, talked to tres @ martin marine and he had them in stock
carter38 03-10-2004 12:42 AM
Westmarine I bought all new ones last year they had to order them but they got them in less than a week.
carter38 03-10-2004 12:45 AM
Also go with the 30lbs I went with 20lbs. first but ended up replacing them if you didn't watch it the wind could get it and knock it down.
cig1988 03-10-2004 06:34 AM
Carter, How much were they and do you have a part#?
Partycove 03-10-2004 11:31 AM
I need to order new ones as well. Bud sent me the wrong size for the door and not enough power. The least bit of wind and SLAM.
carter38 03-10-2004 12:19 PM
I will try to fing a part #.
birdog 03-10-2004 12:48 PM
I just called Tres Martin for mine & he sent them....
No muss--No fuss:D
Partycove 03-16-2004 12:09 PM
Any one find the Part number? I emailed Tres and he needs the old shocks to match up. well when I ordered them new from Cig I tossed the old shocks. Cig also sent me shocks that were just a little bit short for the cabin door lift.
carter38 03-18-2004 01:55 PM
It is a attwood shock here is all the numbers on the shock.
3334ME 0050N 289/01 A3
SLA-10-1
This is a 10lbs. shock I would go with the 30lbs. because I had to replace the 10 do to the wind. Hope this helps.
Partycove 03-19-2004 08:37 AM
Thanks!
Partycove 03-26-2004 10:51 AM
If any one is interested.
http://www.eders.com/catalog/showdet...81&CATID=15127
