My boat is so old.....
1 Attachment(s)
It's got hieroglyphics in the cave (Cabin):D :D :D
Possibly the first drawings of a canopied Cigarette!!;) |
1 Attachment(s)
I have some panels out of the closet on the port side of the cabin entrance. GOOD WORK JOSE' !!!
Does anyone know what these numbers are in reference to?? |
"Jose was here"
What are you doing in there Craig ??????
I found Jose's name in my 1988 Bullet!
I think I found Jose's rasp (file) in the '89 Bullet when I replaced the raw water pump for the head.
I looked in the bilge of my boat and not only did i fine Jose I also found Hose B
1 Attachment(s)
Originally posted by birdog What are you doing in there Craig ?????? I'm reconnecting and replacing all of the parts for the the fresh water system. The pump was disconnected and the switch on the dash was used for the CMI tips with the air pump and flaps that open and close on the tips. I disconnected and removed an old Loran system which the control box was mounted in that closet and used that circuit for the water system which is controlled by a switch on that panel just inside the cabin. If there could have been a video camera on me when I turned on the pump, I would have won some money!! :D :D There are a series of three T's that are connected together which splits the water to go to the two sinks and the transom shower. One of the hoses was not hooked up, so I squeezed my fat azz into the closet and put my finger over the hole in the T. I reached around and found the switch and when I turned it on water squirted out of a cracked T on the bottom and hit me square in the forehead!!!:D And I cleaned up the wiring while I was in there. |
1 Attachment(s)
Before
1 Attachment(s)
After;)
One of my hoses was off when i bought mine...First time i turned the pump on i filled my bilge !......It is kinda tight in there !:D
Mine Freshwater work pretty good. I had some build up in the cockpit floor faucet late last year that I need to check out. I might have to replace the pump some time soon because it does not seem to be full force.
Originally posted by Boatme I looked in the bilge of my boat and not only did i fine Jose I also found Hose B |
:D :D :D
1 Attachment(s)
Old Stuff
1 Attachment(s)
New Stuff
Nice job!
| All times are GMT -5. The time now is 02:31 AM. |
