Bullet question
Looking at buying a Bullet, I was told that they have specific areas that develop stress cracks. Is this a factual statement? If so what areas should I be looking at?
Thanks Russ |
The only thing i have seen is the tight radius around the dash....Nothing bad,The glass must be 1/2 inch thick there so i dont think it will be a problem.....
Not bad for a 15 year old boat eh ? |
Thanks Birdog This guy was saying there are a couple of spots in the cockpit that develop cracks in all bullets
I have only seen one on the right hand side of my dash where they tied it into the hull and its very small. nothing to worry about! all elsewhere is sturdy and solid. i would like to know where he says these are.
Bullet proof
He was saying around the dash, at the step-up by the bench( which I did not know the Bullet had Thuoght that was on the cafe and gun) and by the cabin door. |
Mine don't have any on the dash. But I think you are talking about in the back right in front of the air vents. Mine has a few there. I have heard most do unless fixed at one point.
Only stress cracks I've seen were the ones all have mentioned. My '88 has them by the air vents and dash, '89 only had them by the dash. What I would look for is the condition of the rear seat base. They are notrious for rotting away as well with the engine hatch frame. Pop open the rear bench and start looking for any "compost".
Thanks guys
Are there any other notrious flaws that I should look for? |
Originally posted by RUSS SR1 Thanks guys Are there any other notrious flaws that I should look for? Russ, Just make sure that you get a survey!!!! Craig:) |
thanks for the replies guys..as far as the rot, it is good to check the seat base but if its like the rear hatch part that gets covered, its made of fiberglass but has wood attached. its pretty easy to replace so its no problem. as far as the actual hatch cover, mine was balsa cored and it was an 89 model.
| All times are GMT -5. The time now is 11:33 AM. |
