Mystique
just was wondering if anyone has a 30 mystique
and how it runs/handles |
Stepped ones run nice..Strait V's need some tab to keep them from porpoising
I have a non stepped and am very pleased, yes a little tab is required, but what the heck. Top end an honest 80+, with 500 efi's, and Cigarette quality, with the Top Gun looks, yet easy to trailer, and handle.
thanks,
what year cig30? did it come w/ 500 efis or swapped later ? |
I looked very long and hard at a Mystique before buying my 35 TS.
In the end, there were a few things I didn't like about the Mystique that made my decision for me. 1. Less room in the cockpit. If you study pictures closely, the rear seat is VERY close to the bolsters. 2. Rough water handling. Although it is a great hull, there is no substitute for lenth of hull in the water. 3. Price per foot. It doesn't cost much more to 5 more feet of boat. 4. Resale. Although Cig makes a GREAT boat, the 30' seems to have a limited market because of the reasons listed above. It seems as though people upgrade to either a 35 or 38 soon after buying the 30. 5.No longer built by Cig. I'm guessing there is a reason. I think the cost of building a 30' boat is close to a 35 or 38, yet they don't command the price of the bigger boat. See #4 above. Now, if you are serious about buying a Cig, and are looking for a great boat with good resale, awesome performance with stock power, and attention grabbing looks: Click Here!! |
Does anyone know what happened to the mold or where it came from did they make it just for this boat or was it a cut down from something else!
Cigarette still has the mold, and will build another for the right $. Call Harry @ Offshore Performance. Still a lot of boat for the money. The mold was designed as a small Top Gun, same looks and quality, but was later found not to be as profitable.
Thanks for the info!
Anyone know anything about this one?
30th Anniversary Edition, looks sweet, but mild power. How fast? http://server1.offshoreonly.com/geoc...php?a=15&b=310 Can also be seen here... http://www.tmoffshore.com/BOATSALE/214cg/214cg.htm Ad says twin 425HP...I thought 454MPI's were 330hp? |
If I could buy a boat right now that would be the one. NADA says 107k low to 125k high, and they are asking 83k for it. I would buy it.
454 Mags EFI/MPI are 385 box stock. That boat has aftermarket exhaust and who knows what else so maybe they are estimating HP.
Von, if they're MAG's, then you're right...it didn't mention that but I'd hope they are at least that. That would be nice, stock power.
Mirage, I did check NADA, that's what I got also. Looks like a nice deal. Hmmm... :cool: |
ABOS says $99 to $134 depending on power. If they aren't mags that could be why it is so cheap because 660HP isn't going to make that boat perform real well.
Even at 385 per side it's probably a 70mph boat. A stepped hull with 496ho's ran high 70's on Boat Test. Not saying it isn't great buy but probably be wanting to add different power or super chargers sometime down the road. |
Originally posted by mirageman If I could buy a boat right now that would be the one. NADA says 107k low to 125k high, and they are asking 83k for it. I would buy it. |
Originally posted by Von Bongo ABOS says $99 to $134 depending on power. If they aren't mags that could be why it is so cheap because 660HP isn't going to make that boat perform real well. Even at 385 per side it's probably a 70mph boat. A stepped hull with 496ho's ran high 70's on Boat Test. Not saying it isn't great buy but probably be wanting to add different power or super chargers sometime down the road. |
Does anyone have any pics looking down at the cockpit...trying to get an idea of layout and roominess.
Thanks. |
Nick, Call Blume over at Nation 954 605 8836 cell. He has a 30 down at the Ft Lauderdale store. I looked at it while killing time with G.L down there in Feb. It was real clean with the Flag graphics and 496 ho's
You know the rest of the deal with them. If there is a deal to be made, the can make it happen. I was going to call you and suggest this rig anyways. I really think this would be the way to go for you instead of a older Gun or Cafe that has the potential to be a money pit. This 30 is new technology and should be trouble free. Then if you do want to upgrade, just go back to the boys at National and they wont kill you on trading up Bob |
Originally posted by Baja Daze Does anyone have any pics looking down at the cockpit...trying to get an idea of layout and roominess. Thanks. Nick, Not much difference in size of cockpit from what you have know. Maybe even a tad smaller with less room between back seat and bolsters. But there is 5' more nose and a little bit bigger sunpad and that aint hard to take. Besides, As the great G.L. Harvey once said about cockpit space while standing in the drivers Bolster of his Tiger. " My 2 square feet of cockpit is VERY COMFORTABLE, thats all I care about, What more do I need" GOOD POINT !!!!!!! Its all good Bob |
Originally posted by OTIS311 "My 2 square feet of cockpit is VERY COMFORTABLE, thats all I care about, What more do I need" Thanks for the tip...I'll look into that one as well. |
Anyone know how fast a 30 TS is with a pair of 496HO's?
Nick, I was told around 75ish , I have a buddy that has a 30 mystique with twin 575's what a bad a$$ ride.
1 Attachment(s)
Ask and yea shall receive:
Test Results RPM MPH Knots Total GPH MPG NMPG Range NM Range dBa 1000 6.2 5.4 6.00 1.03 0.90 149 129 88 1500 8.2 7.1 9.20 0.89 0.78 128 112 92 2000 9.4 8.2 14.4 0.65 0.57 94 82 92 2500 9.8 8.5 19.6 0.50 0.43 72 62 95 3000 12.5 10.9 24.8 0.50 0.44 73 63 97 3500 50.5 43.9 31.8 1.59 1.38 228 199 107 4000 61.0 53.0 40.8 1.50 1.30 215 187 107 4500 68.8 59.8 53.0 1.30 1.13 187 162 108 5000 73.7 64.0 65.2 1.13 0.98 163 141 109 Test Conditions Time To Plane: 12 seconds 0 to 30: 6.8 seconds Test Power : 2x425-hp MerCruiser 496 MAG HO Transmission: Bravo One Ratio: 1.5:1 Props: 26 Load: 3 persons, full fuel, no water, min. gear Climate: 80 deg, 80% humid, wind: 20 knots; seas: 1 foot chop |
The 30' at Martin, is with out a doubt the roughest Cig I have ever seen. You cannot compare that boat to anything. It would cost a small fortune to even bring it to "fair shape". Motors worn, needs paint, interior etc. Boat has never seen soap and water, note the port side is not shown ...... there is a reason ....
Thanks guys! :)
Von Bongo, that's perfect. Cigarette 30, that bad huh?...:( What a shame. Tres said it needs a little "TLC." That would explain the incredibly attractive price. |
Originally posted by Baja Daze Anyone know how fast a 30 TS is with a pair of 496HO's? Enrique Eglesias had a T/S Mystique that had some hopped up 575's pushing somewhere in the 600hp neighborhood. The boat would do 100. |
Nice...:D
That's got to be a hell of a ride! Thanks. |
Originally posted by PokerRunGunT/S Enrique Eglesias had a T/S Mystique that had some hopped up 575's pushing somewhere in the 600hp neighborhood. The boat would do 100. |
Nick, Did you call down to National yet and see what they have to get for the 30 they have
Ok, What's the deal with the different hull designs on the 30 Mystique. It sounds like there was an early design that had lots of problems. It was then updated somehow to ride better, (faster?). Then there was a notch added. Then steps were added. Does anyone know the actual time line of these hull refinements and what effect they had on performance?
I've seen pics of the old "Enrique Eglesias" boat. THAT was one sweet ride!! Now, if I could just find a way to afford to even fantasize about it... :rolleyes: |
Bob, I talked to Blume briefly...I'll call you tonight.
Gordo,
My understanding is that the earliest ones were straight bottommed and tended to porpoise a little. Nothing major, just barely noticible and could easily be fixed using a little tab/trim. The twin-steps rode great and were quite fast. No problems with that hull. Then either of the above two, some had pads, some didn't. I heard the ones with pads didn't handle so great, but only what I heard. |
496ho t/s 30 will run 79 all day long... sea trialed the one at offshore performance before i bought my 35... any one who say the cockpit is to small... just lookj at how small the tigers cockpit is for 4x $$$... geat boat i just went bigger because of the intested rates at the time but maint $$$ will be much less... imj spending 10k on motor rebuldr now
| All times are GMT -5. The time now is 04:30 AM. |
