-   -   750's with bravo's (https://www.offshoreonly.com/forums/cigarette/87121-750s-bravos.html)
twin screws 09-16-2004 03:37 PM
750's with bravo's
Was going to order a 38 with 750's, but was told they want stand that much hp. Would appreciate advice from soom of you guys who are running big power.
Thanks Robert
jawbreakerkid 09-16-2004 03:48 PM
Re: 750's with bravo's
i ran my old F2 38 T/S Gun w/ +700HP mated to IMCO Extreme Advantage SC's and never had a hint of a problem.....then again, the boat only weighed approximately 8,200lbs. taking off, exiting and reentry are the hardest on the drives.....
chad
thisistank 09-16-2004 04:09 PM
Dont you mean "750's w/broken bravos"!? :D :D
Just kiddin, I'm runnin 650hp through a standard Bravo...no probs...Then again my boat only weighs like 5k :rolleyes:
Chad, whats the deal? You sold Speed Racer? What's next? Who has S.R.?
Jeffrey 09-16-2004 08:47 PM
Thanks Robert
Simple answer. 700+hp and Bravos in a 38' boat = broken drives. Even if you have been lucky and only had minor drive problems (ie. a broken clutch cone or something) - you will always be thinking about your drives when you are pushing it. I know a few guys who are scared to run hard simply because they are worried about breaking drives. I'd rather have less power and more drives all day long than more power and less drives. I know someone with 575s and #6s. Downside might be a little loss of power since it takes more HP to turn the bigger drives but darn it - you can run balls to the walls in all types of water all day long and never worry about your drives letting go! That's why Gary and I love our "stock" power and XR drives. We ran the crap out of our packages during our poker run - flat out all the way to Catalina and back. Granted - the way Gary (Cigarette 1) drives he's lucky he didn't blow his drives. Can't throttle for his life! Ha ha ha ... ;)
TIGER-1 09-16-2004 09:02 PM
I had 600sc with bravos and broke drives-to much power
I have 750hp's with 3a's and they do great-never any problems
RJ1340 09-16-2004 09:41 PM
3a's at the minimum. anything less is a breakdown waiting to happen
cigarette1 09-16-2004 11:07 PM
Poodle :doggy:
twin screws 09-17-2004 12:56 PM
Thanks for that info guys. The dealer said the new mercs should be here as early as the Lauderdale show. I think I'll wait till there available.
imongo 09-18-2004 07:10 AM
Pulse... Have had mine for 2 years. Drive maintainence = rinse with fresh water after the boat comes out. I do not throttle, ever, even in 6 footers at 60.
Biggus 09-18-2004 07:41 AM
Glad to hear you are happy with the Pulse drive system. I had followed the conversion of Zero Cavity an '88 Top Gun and later heard that is was converted back to Speedmaster III drives.
Did they not work on the Top Gun?
Why did they put speedmasters back on the boat?
