-   -   want to winterize my own tg (https://www.offshoreonly.com/forums/cigarette/88108-want-winterize-my-own-tg.html)
pasunbum 10-04-2004 08:57 PM
i would like to winterize my own 04 top gun with 525`s . I keep it indoors in a heated building, butt would like to protect myself should the power go out. cigarette dealers are hard to come by in pa, thanks for you help, don.
InXS 10-05-2004 09:34 AM
Re: want to winterize my own tg
I winterize my '02 Tiger (575SC's) each year my self by just doing the standard winterization process you would do on any boat. Mine also stays in a 60 degree building.
Change the engine and drive fluids to fresh.
Warm the engines with a water hose thru the engine flush ports inside the engine compartment, once hot, I let the engines pull through 5 gallons of antifreeze each. (You could pull the thermostats to circulate the antifreeze also)
And fog the engines when about the last gallon of antifreeze goes in.
Have done this on all my boats and have never had any problems.
Hope this helps.
