-   -   97 Kevlar Top Gun build Up! (https://www.offshoreonly.com/forums/cigarette/90074-97-kevlar-top-gun-build-up.html)
WildWarrior 11-08-2004 07:55 AM
With the addition of 345cc AFR alum heads ,JE pistons ,Comp cams rollers etc, our 300hr 600SCs will now be a Conservative 750 + hp each and will now spin a 30 prop in place of her 26 4 blades..
I have searched this forum high and low and still need drive advice.
I don't want to go with #6s in place of my stock Bravos,do I need torsion bar shafts? Will extension box's change my great ride? Can my Bravos be beefed up and live? Konrads? Anybody have a similar set up that doesn't eat drives?
The existing set up planes right out ,nets us 82.5 GPS mph if it's choppy enough and and rides great.
We have a serious oil temp problem especially on our Starboard motor after a few minutes between 4000 and 5400rpms.So in as much as the motors need to be pulled we decided to bump them up a bit, other wise I wouldn't mess with a good combo!
Any drive advice would be much appreciated.
Thanks in advance! Glen
RedDog382 11-08-2004 11:41 PM
Re: 97 Kevlar Top Gun build Up!
Sounds like Max Machine is well respected as far as Bravos go. Just upgraded 3/4 of my hardware to their stuff on my Formula 382 with 650 H.P. this summer, but haven't got enough time on them yet to see if they will hold up. I'm at 10,400 dry weight, you should be less.
Might want to check for blockage in you oil cooler on the one motor. Might have some chunks from an old impeller in there.
WildWarrior 11-09-2004 07:15 AM
Thanks RedDog,
I have been out of the boating seen for 20+ years and that was a single outboard flat bottom, my Gun is my first large performance boat and i'm hooked.
I have spent my free time building and racing blown alcy race cars.
It seems that not much has changed in the boat drive department,the power part is simple, but it seems that unless you want to spend as much as the motors on drives ,were pretty much out of luck!
I am leaning toward the Konrads for my application unless I can find a similar combo that is worked well for you veteran boat guy's.
Thanks! Glen
customryder 11-09-2004 05:41 PM
do you have a picture? i was told their were only seven built in 1997?
lucky strike 11-09-2004 06:12 PM
3 Attachment(s)
I know of more than 7.
Here goes
1) 1997 Top Gun with 600 Hawks
2) 1997 Top Gun with 600 Mercs
3) 1997 Top Gun with 600 Hawks
lucky strike 11-09-2004 06:13 PM
3 Attachment(s)
4. 1997 Top Gun HP500
5. 1997 Top Gun 700HP Cheifs
6. 1997 Top Gun 500EFI
lucky strike 11-09-2004 06:15 PM
2 Attachment(s)
7) 1997 Top Gun 502MPI
8) 1997 Top Gun 600 Mercs
lucky strike 11-09-2004 06:16 PM
Yeah, what now? :D
LS JR.
WildWarrior 11-09-2004 06:32 PM
1 Attachment(s)
There is a pic above on the trailer , here she is on the bay a 97 Lipship Kevlar Gun.
customryder 11-09-2004 06:54 PM
now im confused i receved this email today. approx how many were built?
INBOX: Email 5 of 85
From: "Scott Smith" <[email protected]> [Add to Address Book] [View Source]
To: <[email protected]>
Subject: RE: scott smith (fwd)
Date: Tue, 9 Nov 2004 15:00:20 +0000
Yes, I built the 1997 Lip Ship Top Gun. Cigarette was almost closed. Neil Hernandez and I hired all the best riggers and built 7 TG's in 1997. Craig hired the laminators to build the parts, My company CRT Service finished them. They are some of the best built boats ever made. I was personally on them every day to ensure perfection. I don't want to sound like a snob, but my 14 years at Cigarette I demanded perfection. I cant tell you how the boat is now, but it was perfect then. The engines where very strong.
As far as the second one same. Neil and I put allot of individual attention to all 1997's, more than others because those where only 2 of 7 we built the entire year.
Have Fun
Thank You,
Scott V. Smith
Dragon Powerboats
954-614-7076 cell 800-249-5334 office
www.dragonpowerboats.com; SVS @dragonpowerboats.com
-------------- Forwarded Message: --------------
To: www.dragonpowerboats.com
Cc: [email protected]
Subject: scott smith
Date: Tue, 9 Nov 2004 01:47:22 +0000
Hi Scott, do you know anything about this top gun? 97 lip ship 600sc kevlar looking for a top gun & this one is on my list. also the one with the red white & blue ribbon paint with 600 hawks 97 Thanks Jeff
scottsumrall 11-09-2004 07:38 PM
also, another 97 same paint as the last topgun pictured, but pink in color and 525 mercs. that make 9.........................................
jawbreakerkid 11-10-2004 08:35 AM
i'm thinking there were only 7 Top Guns built w/ the Kevlar layup and Merc600's in 1997. however, i could be wrong... :D
chad
scottsumrall 11-10-2004 09:09 AM
chad
i think your right, there were only seven built with 600's and 15 total built in 97.
kevinr 11-12-2004 10:28 AM
Wild, Been researching the same thing for my 89'TG. Only big difference mine has trany's already. Read all the threads on Konrad , from a machinist view , very impresive and they have proven to be reliable, but they just dont look as cool as SSM III - VI's . The SSM's just look like they have less drag, plus they run over the hub style props which give moore surface to prop contact. If you go to the SSM's I think you have too relocate engines, tailpipes ect...... Hard decision to make (atleast for me) ,because of your year model,any money you invest, it will increase value. Not so sure that is the case with mine.
The Menace 11-14-2004 11:16 AM
My 97 Kevlar Gun is the third one pictured on the lift at the beginning of this thread. I will agree that this is one of the best built boats I have seen. The detail, finish, fit are excellent. The 600's were strong. A bad bearing in one blower ate the rings out of my port engine. Only 214 hours. :eek: Both engines are both being bored to 540's and will be pushing + 700 hp: new JE pistons, rods, crank, jesel rocker assemblies and 671 blowers. I trotted a solid 77.6 with the 600 SC's Hawks using 15.5 x 28 4 bladed bravo props.
At least new 30 pitch props in my future. The boat is currently at TNT. The engines are being done by WESCO. TNT refreshed the drives a year ago. Now TNT is dropping the lowers and having them beefed for the additional HP. Need something done right? Go to the people who know. Don't have somebody who works on lawn mower engines for boat make decisions what to do with your big blocks.
When I was looking for props for my cat with twin 1000's they calculated what I needed. They had a used extra set. Perfect slip, perfect rpms's, speed etc. :D
The $$$ spent for expertise pays off many times over in lack of downtime and guess work.
