-   -   Strang hoses found in bilge (https://www.offshoreonly.com/forums/cigarette/93133-strang-hoses-found-bilge.html)
gripit 12-24-2004 02:03 PM
When draining my blocks, I found strange hoses connected to the left side of the block where the drain plugs are supose to be. These hoses ran to the back of the bilge in the wire buldles and ran up toward the cockpit and then I lost track of them. Does any body know why these hoses are connected to the block and where they run to? The size of the hoses are 1/2 inch. I think somewhere water goes down these hoses and runs into the block drain plug. Is it some sort of fresh water flush or drain? This is on a Cig Bullet 88 with 420 HP's There are separte hoses atttached to the left side of each engines block drain plug hole????? My mechanic is stumped???
bob 12-24-2004 02:17 PM
Re: Strang hoses found in bilge
Water pressure hoses going to your water pressuer guages?
gripit 12-24-2004 02:27 PM
Thanks Bob, but no. They go right into the left side of the engine block where the drain plug goes. Its strange.
jordy 12-24-2004 02:35 PM
That would be my first thought too.
lucky strike 12-24-2004 02:55 PM
Water pressure would be my guess.
Do you have water pressure gauges ?
L.S.
gripit 12-24-2004 03:01 PM
No, I don't have water pressure gauges. But would that be the correct place to attach the water pressure sender. Also, there is no sender just a hose connection.
Ted G 12-24-2004 03:07 PM
The drain area would be fine for water pressure, and old style mechanical guages used a hose and not a sender, my guess would be water pressure also.
gripit 12-24-2004 03:20 PM
Ok, Majority rules. I guess I will go with water pressure. Its strange may mechanic didn't know. Thanks for your help.
GLH 12-24-2004 03:42 PM
Pull your gauge cover they might end up there and just be plugged if you don't have the gauges.
Cigaretteman 12-25-2004 07:37 AM
Those are for the waterpressure ! GL is propably right they plugged them off some where.
Cigaretteman
US1 Fountain 12-25-2004 10:55 AM
Look for a new mechanic.
mkramer 12-25-2004 11:54 AM
Sounds like water pressure to me, good luck
SKRAMER 12-25-2004 07:53 PM
Thats where my water pressure guages are connected.
cig1988 12-26-2004 06:14 AM
Definetly water pressure hoses. If you go into the head, sit on the bowl and look to the left. Remove the panel directly behind the helm. You should be able to see the hoses and unless someone removed the water pressure gauges and plugged the ends. Alot of times those hoses get plugged up and if they are connected to a psi gauge, run some compressed air thru them. I've had them so plugged up I had to run a wire thru them from the bildge side.
GLH 12-26-2004 08:24 AM
Yup
