-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   Need Kaama Props (https://www.offshoreonly.com/forums/classic-offshore/197252-need-kaama-props.html)
don 10-14-2008 10:39 PM
Need Kaama Props
This is getting out of hand trying to find a set of props for my KAAMA surface drive. What options do I have. People have said they have them but no one comes thru. Please do not think I am complaining but does anyone have a set of props that will fit on my KAAMA 19 spline short shaft. I had a set stolen and they were cleavers with KMA serial numbers on them. They were 17x24 short hubs ( spline is about 3 inches) solid hubs. DOES ANYONE HAVE A SET FOR SALE AND IN THERE HAND? I have called all over and no one has them. Is there a different type of prop I can use to get this boat in the water? I was told this boat will go over 100 so I need a reasonable stable prop. Merc #3 spline is the same but can I use a standers prop? I can go to a 18 dia and a 26 or 27 pitch. 3-4 blade just 19 spline short shaft. HELP PLEASE!
I'CE 10-14-2008 11:01 PM
short hubs
don, how are u ? are u well ? anyways, remember where u-got the gears ? they made the shafts too, I believe, that was Cassele Eng. 310-906-4825-7 think the guys name was Andy ? any ways I know it would be a real pain in the butt, but if worse came to worse maybe he could cut some long shafts for you. just a thought sorry about all your troubles ! J also why don't you call Throttle Up or B-Blades for some advice, best of luck with your quest ! --- also why not post in the prop. section of OSO ? :)
26sxl 10-16-2008 09:44 AM
Don,You should PM Perfectmix (Josh) I think he might be able to help you out. He's been there done that...
don 10-19-2008 01:22 PM
Hi Yall Thanks for all the help and I am doing so much better. I just need the props now but the short shafts are the problem. Called a guy in Ft Lauderdale yesterdy and he got me a set!!! YEHAAA! I Want to say thanks to you ICE cause yo da man!
BOATMAN302 10-20-2008 11:09 AM
Have A Set Of 3 Blades That Came With My Boat, Hung Them Up On The Wall Yesterday, If Your Florida Guy Doesnt Work Out. Bruce
I'CE 10-28-2008 10:16 PM
Bruce, how are ya ? did NO boating last yr, fuel, u-know, may still need a part or 2 give ya a buzz if so, catch ya later J :cool: ps AKA "1CE"
I'CE 10-28-2008 10:20 PM
don, who did ya get the props from in FT.L. u-goin to the K.W. races ? :)
tnt1 10-29-2008 12:59 AM
I have aset of 17-24 3 blade short shaft for kaama drives
Cig35Mistress 10-29-2008 09:00 PM
Don,
I've got a set of stainless Speedmaster Cleavers, solid hub, 19-spline . . . they are 14x22 R&L. I don't know if they'd work for you or not. EMail me at [email protected] if you're interested.
Thanks,
Harry
I'CE 11-02-2008 09:25 PM
guys, don, just posted on the stolen section of OSO that his boat was taken man what luck he has had, can't belive it.
