WANTED! Holman Moody water pump plate
2 Attachment(s)
I'm in desperate need of an old Holman-Moody, crank driven waterpump adapter for a buddy's old 351W Ford powered Donzi. The cast aluminum plate is all we really need as it seems the rest of the coupling is a Love Joy component. Anyone got one laying around???
Thanks, Kurt 715-410-0735 |
Plate
Can't you have a machine shop make one ?
sorry mine are 4 bolt not a 3.
i have 2 ford hm 302 just rebuilt. i recommend just get a new water pump and rig to fit. nick |
I'm sure a machine shop could make one but was hoping someone had one laying around, just remove and replace. I'm told that the coupler is just a standard Lovejoy component. If someone had the plate it would be running for the weekend.
Any help would be appreciated! Kurt |
switch your entire pump set up . . get rid of the totem pole bracket mounting plates and long bolts and switch to a crank hub mounted pump.
My Donzi Corsican had what you have, and when you break a belt in the middle of the pond, taking that apart to replace a belt sucks! Mario L. |
crank pump is the way to go
Originally Posted by thescooter
(Post 3742921)
Anyone got one of these laying around? Thanks again, Kurt |
get the plate made?
(Post 3743830)
get the plate made?
how close would a dry sump oil system drive mandrel fit and work.
| All times are GMT -5. The time now is 01:06 AM. |
