-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   Bought a an old blue thunder (https://www.offshoreonly.com/forums/classic-offshore/293721-bought-old-blue-thunder.html)
ahlenius 03-28-2013 11:03 PM
Ok bought this boat Now i need to move it from Ny to TX. Its on a great trailer with surge brakes do i need a permit? boat is 11'6 wide gonna pull with dodge Cummins power not an issue! The boat has an "OVER SIZED LOAD" sign any ideas?
Tom A. 03-28-2013 11:07 PM
Anything over 8' 6" wide needs a permit. If it were a 9' v bottom you could get away without permits. You need to check each state and see what the regulations and permit $$ are. Every state is different.
MILD THUNDER 03-28-2013 11:59 PM
Youre definitely gonna need permits and a pre planned route.
That's a very heavy boat, hope you got a strong transmission. My buddy has one of those and its a tank. Good in rough water, just not fast at all. With twin 600's he runs about 68-70mph
phragle 03-29-2013 12:18 AM
you just bought the ultimate party barge!!
sprink58 03-29-2013 04:36 AM
You probably know the history...down here they are legendary for their ability to handle rough seas at high speed. They are not light and fast but will stay on course and in seas that beat everyone else up...run you down!!:evilb:
A pair of 700 Horse BBC's or better still Big Diesels with 1000 # of TQ will move that big rascal.
pat@osp 03-29-2013 07:20 AM
Yes, to be legal you need oversize permits for anything wider than 8' 6". On some stuff you can slide past if you're towing with a pickup on a regular boat trailer and it doesn't look too wide but no away around the fact that this will look really wide going down the road. You'll also have to plan accordingly to follow an oversize legal route and submit that for every state as part of your application along with truck and trailer info like GVW, axle spacing, weight over each axle, overall dimensions of everything, tire sizes and load ratings, etc. There are permit companies that can help you with all this.......they typically charge a flat fee per state permit plus a small percentage of the state cost. Most of your route to TX should be pretty easy to plan.......biggest hassle will be NY depending on where your starting from. Anything near the city or thru NJ takes some planning and if you are coming off Long Island with anything over 9' 6" your better off taking one of the ferrys vs any of the bridges and dealing with NYC DOT. Since the hurricane they've clamped down even more on the restrictions around NYC and some parts of NJ. Another thing about NY is that they have different permits depending on what type of road you're traveling so in some cases you need multiple NY permits. Again a permit company will be able to help with that.
Pat
[email protected]
pat@osp 03-29-2013 07:47 AM
Couple things I forgot to mention. Typically NY will not deal with you directly.............they require you to work thru a permit company. Also most states limit you to day time travel on Monday thru Friday with some states allowing travel up until noon on Saturday. You'd be pulling whats called a "one time" permit and the effective dates of the permit are different in each state...........typically they are in effect for 3 days to 1 week from the travel date you pull them for. All the requirements will be spelled out on each state permit for that state. So anyway, that is what's involved with getting permits to do it by the book. None of it is a big deal really, just takes some time and pre-planning to get it all coordinated properly so some guys will take thier chances with no permits and hope for the best. If anything changes and you decide not to do it yourself get in touch and we can give you a quote.
ironhead 03-30-2013 04:42 PM
call "comdata" have a credit card and all license plate #s and your state by state route thell do all the permit stuff, they do all my out of state trip and fuel permits
h2oboater 03-30-2013 06:45 PM
Rob you use permits now :party-smiley-004: Back in the day you used that special tape measure when towing the Motor City Magic cat. :evilb:
ahlenius 03-30-2013 10:21 PM
Ok Thanks for all the Help I am going to permit for all the States, found a reasonable company! Also Thanks Tom will see you in a few days. Ok here is how the Cat is powered anyone feel free to comment good or bad. Brand new 546 big blocks with Aluminum heads topped off with whipple Super Chargers, 800 Dominator Carbs MSD electronics, 900hp each. Connected to Brand New Huber 1450 Transmissions with rebuilt SSM-3 Drives. You need to see the Props!!! Perhaps just a step up from the ultimate party Barge! Also Tom, Rob has starboard engine running sweet! Just some fouled plugs I will post pics when able, needs lip stick and rouge!
MILD THUNDER 03-30-2013 10:27 PM
546ci? That's a odd number. What size whipples? Single carb or dual carb setup? If truly making 900hp each, I'd imagine mid to upper 80's. hardware sounds nice
ahlenius 03-30-2013 11:38 PM
Ok sorry 540"s, 6psi boost, Runs pump gas, and will be a great family boat. Only after church on Sundays! Single Carb application 800 dominators i think? Tom feel free to add!
MILD THUNDER 03-30-2013 11:41 PM
Single carb 540 with 6lbs of boost, definitely not 900hp. Maybe 700-750 with a 1050 dominator
ahlenius 03-30-2013 11:53 PM
will it still be fun?
hogie roll 03-31-2013 08:12 AM
What size whipples? That would be a good indication what kind of power they're making. And yes 800 is small for a single carb.
fastdonzi 03-31-2013 10:36 AM
Put the boat in the water, Fill it up with fuel and head south down around key west, then head up the gulf, Texas is right there, Can't miss it :).... Sounds like a good trip to me....
ahlenius 03-31-2013 08:58 PM
As Soon as I find out the exact specs of the motors ill post it and pics(if i can) but looking forward to floating it!
Velocity Vector 03-31-2013 10:27 PM
Congrats on a old classic. Did someone say big & heavy
http://www.youtube.com/watch?v=baSLurBO9CQ
ahlenius 04-05-2013 08:07 PM
WOW Long Trip towed the cat home from NY State took 2.5 days. I secured all the permits required (what a hassle!) but worth it. Man is it Heavy! My Dodge Ram 2500 Diesel and the boat on trailer were 26500 lbs across the scales. Any way 540 cubic inch engines Whipple 3300sc'S and 1050 Dominators, Huber 1450's and SSM#3 builder says @ 850hp They run great! I have a little lipstick and rouge and some cooling enhancemants to do, but other than that its all good. here is the Boat serial #URT39046G990 any body have any info on its History? any comments? Thoughts
MILD THUNDER 04-05-2013 08:30 PM
My guess is the truck alone is around 7000-7500 lbs, so boat and trailer around 19k? I had my F350 super duty with my Formula 402 SR1 on the scale before. With no fuel in boat I was 24500 total. Truck weighed 8000lbs. Boat and trailer 16500lbs.
IMO , boats like that are way to much for a 3/4 ton, and 1 ton. How did the dodge pull it?
Boat engines sound like nice builds. Did you run it hard yet?
ahlenius 04-05-2013 09:17 PM
Dodge pulled it fine its motor is broken now for sure. Its a hell of a truck 2011Ram 2500 pulled that tub of lard like nobody's business highest mpg was 8.9 but secretly i think its glad its gone!!! Wont be working on the boat for a week or so as to have to catch uo at home. How do i post pics? i am only a basic member
sprink58 04-05-2013 10:21 PM
Get a free account with photobucket.
ahlenius 04-24-2013 10:15 PM
Ok so go into photo bucket and get a free account then youse the link to upload here?
CigaretteSam 04-25-2013 08:30 PM
Yep, thats exactly how its done.
