-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   Mercruiser MR outdrive question (https://www.offshoreonly.com/forums/classic-offshore/294157-mercruiser-mr-outdrive-question.html)
sprink58 04-27-2013 05:04 AM
Originally Posted by vintage chromoly (Post 3902808)
The mr is not the same as the alpha. It came out before the alpha and is interchangeable with the alpha.
I have an mr behind a warmed up 188 (302 ford) mine makes around 300 hp and is in a 1975, 19 foot, searay.
Mine has held up fine with yearly gear lube changes. No hole shots or air and it will survive behind a 300 hp smallblock.
I can testify to this scenario with a 18' Formula...same power...same drive...9 years....9 x 12 month boating years.
