-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   Help with Cleaver Prop mounting on TRS (https://www.offshoreonly.com/forums/classic-offshore/338197-help-cleaver-prop-mounting-trs.html)
F-2 Speedy 06-15-2016 07:40 AM
These props also use the bravo hub ??
ham_r_down01 06-15-2016 08:18 PM
Originally Posted by phughes69 (Post 4449783)
The spacers are correct. Back when I switched from SSM II's to TRS I had a set of 21' 3 blade cleavers, I too had to use the spacers. As far as the cleavers being faster, I doubt it. You have to remember that the TRS is not a surfacing type of drive. The cleavers were good in their day (30 years ago), but the bravos are a better prop.
They most def aren't on my boat. Man are they deep. I run 25p 3 blade cleavers. They are what came on it when I got it.
ttrm007 07-18-2016 07:09 PM
I have 2 sets of 21p cleavers if anyone interested.
phughes69 07-18-2016 07:41 PM
Are the props RH and LH?
northernoffshore 07-18-2016 11:09 PM
I think those props are the K Kiekhaefer cleavers.. never had much luck with them on trs boats.. always liked the 3 blade mirage or hydromotives
