Originally Posted by TruxtonFox
(Post 4495531)
Does adding the BW require adding in a support for the tranny....currently the merctrans just hang off the motor and slip into the gimbal housing.
Yeah I know what you mean about the 'Project' always evolving... been there! |
Originally Posted by Craney
(Post 4497332)
You said the TRS drives are not designed to work with spacers why is that?
You can add spacers to TRS.
I know there used to be extension boxes for them, but they're few and far between now.
If you're going to run the merctransII trannies, look up KC marine in washington state. Talk to Kirk, he's very knowledgeable on these trannies and the TRS drives. He makes modifications to the merctrans to make it handle the bigger power. The merctrans also takes less HP to turn than the borg warner.
Mine have been bulletproof (except for the one I dropped and busted the case on the floor, and tried to fix myself lol) You will enjoy the extra room in front of your engines. You can actually stand there. They will handle the non recommended holeshots too.. (only did this once) https://youtu.be/VMLeElqcnYA |
Here is some info from bluethunder dave I got years back. Probably had one of the fastest panthers
94mph is my best to date. 90-91mph is generally achieveable. The big helpers from 62mph to 90mph were, raised x dim 2", built stout 650hp blower engines, ground some of the hook out of the hull. Nose cones helped too. And yes, a good 3'chop makes a big difference although a bit of a wild ride at those speed. Which friend of mine were you talking to? Congrats on the new boat btw. One disadvantage you will have over my panther is I have bravos which are faster than ts drives. Dave I needed a new transom so when that was done I cut it 2" higher. My propshafts are 4.5" below the hull. I run 4 blade bravo1 props 32p spinning in at 5300rpm or thereabouts. |
Originally Posted by hblair
(Post 4497783)
Mine have been bulletproof (except for the one I dropped and busted the case on the floor, and tried to fix myself lol) You will enjoy the extra room in front of your engines. You can actually stand there. They will handle the non recommended holeshots too.. (only did this once) https://youtu.be/VMLeElqcnYA WHat kind of price does it cost to get 2 of these built? I'm getting ready to junk my baby velvet drives, for the bigger ones, but this sounds interesting. I actually need to move my engine a inch forward to run the larger drives. |
(Post 4493974)
Anybody out there running 500+ hp on a panther or panther 2 through TRS drives? What prop are you turning and what speed are you seeing?
Sorry I didn't see this post. Seems like they were between 8-1000 apiece depending on what they need. Google "kc marine trs" and go to the website. Call kirk, he's the guy who builds them. I think he's a one man show. He'll take the time to explain everything. One big thing is dump the trans cooling water overboard instead of out the exhaust. It increases flow and let's them run cooler. Also running amsoil synthetic fluid is good for them. Private message me if you need anything else.
| All times are GMT -5. The time now is 01:35 PM. |
