-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   Magnum 27 Registry (https://www.offshoreonly.com/forums/classic-offshore/346359-magnum-27-registry.html)
24degrees 04-20-2017 01:49 PM
Magnum 27 Registry
I'm starting a Magnum 27 registry. If you own or have owned a Magnum 27, let me know the hull number please.
Thanks,
Aaron
lucky strike 04-20-2017 05:53 PM
2 Attachment(s)
In 1973 I bought my 1st what I called back then... My Ocean Racer.
I cant remember the hull number but here are a few pics.
It had 350 Crusader Scorpions with Volvo 270 drives.[ATTACH=CONFIG]566583[/ATTACH][ATTACH=CONFIG]566584[/ATTACH][ATTACH=CONFIG]566583[/ATTACH][ATTACH=CONFIG]566584[/ATTACH]
lucky strike 04-20-2017 06:14 PM
Sport
1 Attachment(s)
Another photo i found [ATTACH=CONFIG]566585[/ATTACH]
24degrees 04-20-2017 09:22 PM
Yep, love that boat....if you can find the hull number I would be thrilled!
scippy 04-21-2017 05:29 PM
My 27' Magnum sport hull # MAG273410476
Drake22.250 04-22-2017 07:44 AM
Hard to read but I believe my sport is 114
24degrees 04-22-2017 10:45 AM
Thanks man!
24degrees 04-22-2017 10:46 AM
Which boat is yours?
Thanks!
24degrees 04-22-2017 10:48 AM
Are you Steve?....I have a note here that says it's hull #216
24degrees 04-23-2017 12:30 PM
Drake...you bought the red and white boat out of Chicago? Make sense that it's an early boat with those early deck vents....got a pic of the hull number? Was it under the dash?
