Like Tree17Likes
Everybody please read this
Old 09-27-2017, 07:02 PM
My Boats: '79 Scarab 300 '81 Scarab 377 Flat Deck
Quote:
Originally Posted by 14 apache View Post
Are the pickups part of the tank? Is there a chance that the screens just got plugged up and shut the motors off? Looks like a bunch of crud on them.
The screens were in the upper section of the pickups. The pickups are now in the bottom of the tank. They broke off at the very top. What you're seeing is the screens.
hblair is offline
Old 09-27-2017, 10:03 PM
BUP
Trade Score: (6)
My Boats: 2017 - 29 Laveycraft Custom Build & SHE's Going to be a Bad Boy. www.laveycraft.com
common problem. I even see the fuel pick up tube that has a rubber fuel hose attached for an extender that has a screen in it. The rubber fuel hose falls off and or comes apart, When the fuel level goes bellow 3/8 of a tank it sucks air. Also seen the rubber fuel hose gum all up as well. Another reason to test with a remote fuel tank and own that set up.
BUP is offline
Old 09-27-2017, 10:09 PM
BUP
Trade Score: (6)
Quote:
Originally Posted by Unlimited jd View Post
Wow, we found the pickup fell off the race boat 2 weeks ago, have about 4' of 1/2" I.d. Stainless tubing if anyone needs some some very reasonably, had to buy minimum $120 worth
I would be interested in this. Let me know pricing
Want to ask is it one 4 ft section or is it cut in lengths that adds up to 4 ft ? THANKS
BUP is offline
Old 09-29-2017, 11:27 PM
My Boats: 78 nova 250
I've been fighting fuel related issues on my 78 Nova 250. I removed the pick ups and looked at them but never ran a wire thru them. I know what I'm doing this weekend. I have been driving my self crazy chasing a lack of rpm for 2 yrs. 4000rpm and 50 to 53 mph.
SB and hblair like this.
Nova250 is offline
Old 09-29-2017, 11:33 PM
SB
Trade Score: (1)
I mentioned this in another thread. 88 Wellcraft this summer....removed fuel sender - float was cork. Drained all the fuel so I could look at fuel tank and found piece of the cork wedged under the fuel pick up inlet. Who would have figured.
hblair likes this.
SB is offline
Old 09-30-2017, 11:31 AM
BUP
Trade Score: (6)
Testing the fuel tank side of things. ie the fuel pick up - anti siphon valve - connections at the tank. One can check vacuum hg s coming out of the fuel line by hooking up a vacuum tester inline and running the engine .
Or take a fuel line with a primer bulb exactly like what outboard boats use. Unhook your fuel line at the gas tank and install your new fuel / primer bulb fuel line. get a clear jar - use the primer bulb to siphon the gas into that clear jar - this also will show the condition of your fuel and if any water present. You will know if the fuel flow is restricted or even a broken off fuel pick up tube by doing this testing as well.
BUP is offline
