-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   1986 KV 38 Scarab (https://www.offshoreonly.com/forums/classic-offshore/350134-1986-kv-38-scarab.html)
lakeland157 10-04-2017 10:03 AM
1986 KV 38 Scarab
WELP2106E686
What are these boats worth,hull and stringers good,been painted with pink n teal to match interior which needs to be redone. I have to get back to owner quickly.502 that needs to be refreshed with blowers.Dart blocks.With trailer.15,000.asking firm should I buy
phughes69 10-04-2017 07:19 PM
That is the one on CL. Been for sale for a while maybe several months. The hardware is worth it with the blowers. Im pretty sure that boat had TRS drives so be careful with hole shots with those drives. Does the boat still have bottom paint? Bottom paint removal can be messy and expensive. Doubt the boat is 100% rot free. Wellcraft boats although better bult than other mass produced boats were still prone to rot. Usually the drainage holes thru the stringers were never sealed and collected water. For the purchase price of $15K, I would plan to spend at least that to fix the engines, upholstery, bottom paint removal and repaint the hull. $3000 to fix one engine sounds pretty low. Figure if it spun a bearing, then new crank, rods, pistons, bearings, gaskets, oil pump, new valve springs, valves, cam and lifters. new oil coolers. When an engine spins a bearing it sends shrapnel thru the whole engine and does nasty things. Since you have one engine out may as well do the other since they both have the same hours or close probably. Its a great riding boat, but their expensive to redo. I'd shoot him an offer of $10 and see what he says.
jeff32 10-04-2017 08:14 PM
you won't make money out of this but could get you a big boat for less than a new one!
hard to tell on worth, but yeah, 10 or 15k might be ok in terms of parts that are on it (trailer 4k, drives, 1500 each, blocks and blower as is... 3 k each?
but it wont make money!
who am I to say it is wrong buying this scarab !
having a chris cat total project boat to redo !!! :)
lakeland157 10-12-2017 11:43 PM
KV scarba
I did finallybuy boat. I think going try sell blowers etc. And try get back to 500 hp range. So I got 3 sets props,going sell 2 pair. I did get a lot of original documents,like brochure for boat.brass plate and never incraved.And tons other things need look through. It is a KV Scarab so somethings people will want. If anyone reads this I would like get boat to run 60 - 65 any ideas how much horsepower I need. And anyone want blowers etc all in working order. 1rebuilt bsm
scippy 10-13-2017 12:42 AM
Can you describe the props that you'll be selling?
lakeland157 10-24-2017 03:27 PM
86 KV 38 Scarab
I bought this scarab. I think there are a lot of people kicking their self for not buying. One motor runs great,other motor runs 110 steady oil pressure,slight knock,and mufflers on that motor turned little blue. Either hot or lean. Going to pull and find out. No metal in oil. Does anyone know the paint codes for the teal,pink,purple. I have talked to two previous owners,never been kept in water. Cabin all original and excellent except rug fade.
lakeland157 10-24-2017 03:34 PM
Also have original brass nameplate from wellcraft and never incraved.And. I will post a few pictures when I figure out how
larslindroth 10-24-2017 07:39 PM
Join us with a thread on Scarab Owner's Forum.
http://www.miamiviceonline.com/image...ger390x/by.jpg
Congrats on a great classic, but join us Scarab owner here on the forum.
https://www.offshoreonly.com/forums/scarab-41/
http://www.miamiviceonline.com/image...ger390x/bv.jpghttp://www.miamiviceonline.com/image...ger390x/bw.jpg
lakeland157 10-24-2017 08:10 PM
1 set is solid hub SS polished 16 x 23 cleavers. $800.00 Firm
endeavour32 10-25-2017 09:22 PM
2 Attachment(s)
You need to be a paying member to post pictures, join the site and post what you have. I bought an '82 Kaama 377 this past July, which is the same boat as yours. I'm finally going to be able to start restoring it in the next few weeks. It was a busy summer and I finally rented a building close to me, so I can get cracking on it. Mine is getting SSM drives and 1000 hp a side. If I were you, I would not shoot for 64 mph. That will get boring really fast. I'd shoot for 75 at a minimum, you certainly don't want to be passed by a family in an open bow Cobalt.
Here's mine.
scippy 10-26-2017 12:13 AM
3 blade?.... 6" hub?....condition?...........would need to see pictures though....thnx
endeavour32 02-23-2018 11:37 PM
lakeland, what's up with your boat? Let see some pictures.
jeff32 02-24-2018 08:29 AM
Good question nice you bring this tread back up!
hblair 02-28-2018 09:42 PM
Yeah come on now show us some photos..
Rhythm and Blues 03-28-2018 12:29 AM
Awfully quiet around here......
endeavour32 03-28-2018 06:39 AM
I sent him a PM, my guess is he did subscribe to the thread. I really would like to see some pictures of his boat. There are not a lot of these boats out there, and it would be great if we could add another one to the list of 377/38 flat decks being restored.
