I have 26 four blades on it It tops out at 80 mph
Still have the cable steering It steers well but around 75 any small wave it gets dicey! I think I could get a higher top end with different blades |
I've always heard the 3 blade props work best on this set-up (with twin BBC's). More stern lift?? Per the orig owner, mine tops out at 83 MPH in fresh water. (A little faster in salt). I haven't got it above 80 since it was getting very squirrelly. Engs are supposed to be right at 500 hp.
It came with 25p 3 blades
I couldn't get it much over 70 until I switched the blades to spin in I didn't have enough bow lift I am guessing I took about 400 pounds off each motor The swim plate form now sits 8 inches off the water There is plenty of stern lift now |
Way back when we souped up 29' Fountain 2x454 mags. Then we put 27 pitch 3 blades had prop shop add 300rpm each 77mph all day long!
Getting weight off the stern is a good thing with these boats. I still have cast iron Merlin intakes. They are seriously heavy. Swim deck on mine is abt 6" off the water.
Yes it makes a big difference!
I went with aluminum everything I could Stainless exhaust and took the silent choice out. The V pipe alone was a lot of weight |
| All times are GMT -5. The time now is 08:58 PM. |
