-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   Velocity 30 set up (https://www.offshoreonly.com/forums/classic-offshore/383576-velocity-30-set-up.html)
tristan247 09-02-2024 03:03 PM
Velocity 30 set up
Hi. Just about starting to refit an early 80s.Velocity 30 race deck.
current set up 502 EFI on 72c uprated 9plate. TRS upper and speedmaster II lower units.
1.5:1 ratio
I’m looking to remove the running gear and use Bravo 1. The speedmaster and TRS and just getting to old.
the TRS are very tall compared to the Bravo. (Not purchased bravos yet)
so engines look like they may have to drop 8-10 inch. There is enough on the sumps to do so.
what is the best X dimensions measurements to run Bravo 1 ? Cav plate compared to pad. Or step of the Velocity.
boat will hopefully be raced in the UK 2025. I raced it before. But have just bought. So new to me and my dad. Father son refit project
CIG3 09-13-2024 06:56 AM
I would give Velocity a ring. They will steer you in the right direction for a single set-up.
tristan247 09-13-2024 07:23 AM
Thanks will give Scott a message.
it’s twin. Sorry wasn’t clear.
