Prop Help...
Hello everyone,
After the Fun Run in the Sun, I have decided that i am going to try and dial my boat in for the last time. I have a 2007 30' with a pair of 300 opti's...So far i have tried 25 mirage's, 26 bravo's, 27 mirage's, labbed 28 bravo's, and labbed 29 mirage's. Not to mention several other props including 25 pitch mercury rev 4's, and some 26 and 27 pitch hydromotives. In regards to engine height, the motors are currently one hole up from the bottom. The reason why I am posting this is to see if one of you guys can at least point me in the right direction as to maybe what type of props I should consider as well as if it would be a good idea to lift the engines up maybe one or two holes. I would really appreciate any input that you guys might have. |
contact Marylandmark or go back thru some of these older post, he as made several on props. He too has tried every prop known to man. He has an 07 I think w/300xs's. He was helpful to me when I got mine, he used to have it on a sheet, what prop ,rpm, and speed, and detailed account of how it handled. He has lots of post here , shoot him a PM, he has alot of info. Good luck
| All times are GMT -5. The time now is 12:13 PM. |
