32 concept spin props in or out?
32 concept spin props in or out.
your test results? |
Spin props out with the drives toed in (front of engines closer than rear of engines) between 1/8-1/4".
When running you want your drives to line up straight like this: I I With props turning out, the waters resistance to the blade is pushing the prop toward the centerline of the boat (prop torque). When the rear of the prop shaft is pushed toward the center, the front of the prop shaft has to open up or move away from the centerline. So you go from / \ to I I 2007 326 with 300XS |
Got some pics? of your 32 please
| All times are GMT -5. The time now is 02:30 AM. |
