-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Installing a pod (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/101855-installing-pod.html)
Quiet Storm 04-28-2005 06:45 AM
Installing a pod
I need four more gages on my dash and I don't have enough room. So I was thinking I could remove the compass and put a pod in its place. I was told there's a lot of prep work to install a pod. I figured to just bolt it on with a bead of silicone around it.
Am I wrong?
hillbilly24 04-28-2005 08:47 AM
Re: Installing a pod
Tou could do it that way and it wouldnt be that big of a deal but it would look alot cleaner if it was glassed in. Glassing it in wouldn't be THAT big of a deal but certianly more involved then screwing or bolting it.
Quiet Storm 04-29-2005 06:43 AM
I think I'm going to start with the quick and easy then have it glassed in, in the fall. Nuts and bolts I can do but I will leave the glass part for an expert.
dyno 04-29-2005 08:22 AM
If you screw it in you can remove it easier.....
