-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Help with Stringers ! (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/127158-help-stringers.html)
IHTFP 04-10-2006 03:01 PM
3 Attachment(s)
I'm restoring a Donzi 22 Classic. The deck is off and I am working on the hull stringer structure. I currently have several areas of rot in the forward (not engine compartment) stringers. The areas of rot are circled in the pictures. My plan was to just reinforce the stringer system with a few more layers of glass and do nothing else. My thoughts were that the glass would handle the load and therefore, it wouldn't matter if the stringer rotted from the inside. Does anybody have any thoughts on this, should I repair the stringer by just replacing the rotten wood, or pull the whole stringer system out and start over with high density foam coring, or just cover it over with extra glass and forget about it?
Catagory5 04-10-2006 07:39 PM
Re: Help with Stringers !
I would, at a minumin, replace the rotten wood. Glassing over the rotten wood isn't going to do much and the rot will continue to grow. If your planing on keeping the boat replacing everything with foam core would be great but it's alot of work. Your already in this far, might as well do it right.
IHTFP 04-10-2006 07:51 PM
I have thought about replacing everything with foam, but I fear that the boat will lose it's shape if I remove the stringers. How would I brace the hull so that does not happen? Would the hull sag or buckle with the stringers removed? Thanks for the help.
Catagory5 04-10-2006 08:32 PM
Yes you have to brace the boat. Brace it from under the hull and i would also use brace across the top of the hull. If your going the whole 9 yards use epoxy and the bond to the old glass will be much better and it reduces the chance the shrinkage of the curing laminant will pull the hull out of shape.
It's not going to be cheap and it's work work than it looks like. But the results should be worth it.
Audiofn 04-10-2006 09:43 PM
I agree with Cat5 100%. Make sure that you have the hull braced very well. It is done all the time and it takes time. What I did in my Formula was only replace a little bit at a time. For example one large stringer on one side, then another on the other side. My trailer supported it very well. I kept checking the bottom all the time I was doing the work. The donzi bottom will NOT be as strong as I was dealing with so more care should be taken, especially if you have a roll on trailer like most do with Donzi's.
Jon
Byrdman 04-10-2006 09:55 PM
Why would you start messing with that hull???....and your going to start putting wood back in there then bonding new glass to the old...seems like a real can of worms for a little rot....how do you know it is rot and not discolered and on its way??...and then your going to strip the hull of all stringers...going to be sorry....never going to be the same! :eek:
hunster 04-10-2006 10:31 PM
Where is Sharky when you need him? :D
Catagory5 04-11-2006 04:00 AM
Your right, if you do it correctly it will be BETTER then ever.
Audiofn 04-11-2006 06:45 AM
:drink: :drink:
resurrected 04-11-2006 07:35 AM
What is the bottom construction of a Donzi?
IHTFP 04-11-2006 07:45 AM
It appears to me to be solid hand laid glass, no coring.
Audiofn 04-11-2006 09:24 AM
Yup
KAAMASCARAB 04-22-2006 12:01 PM
You can drill into those areas to make sure they are wet/rotted. It's a ton of work to fix, make sure the boat is worth it to YOU. Do tons of research, make sure it's RIGHT. It also rotted for a reason, you need to fix that also. I used Nidacore for my stringers-it's a polypropylene honeycomb it will not absorb water ever. use epoxy, the secondary bond is much better. :evilb:
