-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Mounting swim platform (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/127951-mounting-swim-platform.html)
jmackin 04-19-2006 05:10 PM
Bought a swim platform for my Topgun. I am going to thru bolt it. Some will be below waterline and dont want any water intrusion.
Do I use resin to seal holes?
Do I use 5200?
Do I use both?
offthefront 04-19-2006 05:54 PM
Re: Mounting swim platform
I'm sure the experts will chime in but I would oversize all the holes and fill with epoxy and then redrill to the right size ...then 5200 ....m
Prater 04-19-2006 07:51 PM
I second the oversize hole filled with epoxy, then drill correct hole. This keeps water out of the core.
jmackin 04-19-2006 07:57 PM
How much bigger?
Anybody done this? How hard?
Catagory5 04-19-2006 08:27 PM
The above would certainly work but it's overkill. If you caulk it correctly inside, outside and on the bolt with 5200 you shouldn't have a problem.
Check your placement several times, and check the inside before you drill. It might seem obvious but plenty of people get hurrying and drill right into a wire harness, or a hose, or dead into the middle of a stringer.
