-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Primer or not? (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/128137-primer-not.html)
1BIGJIM 04-21-2006 03:22 PM
Primer or not?
Ok this might be one of the most stupid questions posted but,
I am spraying over a faded 4 inch piece of Gelcoat. I dewaxed, sanded with 220 then 400, then 800. Faded green is all the same. I thougth I read on a forum you did not need to apply primer first?
Any comments.
Audiofn 04-21-2006 06:24 PM
Re: Primer or not?
You re gelcoating? If so no you do not need to prime first.
Jon
1BIGJIM 04-21-2006 09:57 PM
Re: Primer or not?
Nope, Urethane Spelling :D
Catagory5 04-21-2006 10:47 PM
Re: Primer or not?
Follow your paint systems recommendations. 800 scratch in gel seems high. Depends on what paint your using. Also it depends on if your changing color.
1BIGJIM 04-22-2006 11:20 AM
Re: Primer or not?
I put on primer. Story over :drink:
Gmoney52 04-22-2006 11:58 AM
Re: Primer or not?
For future reference, single stage doesn't necessarily need primer, but a sealer to play it safe, especially if painting yellow so you have uniform color. I usually sand with #320 before painting, but #400 if you use Awl Craft 2000.
