-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   painting bottom? (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/129260-painting-bottom.html)
erpsdog 05-04-2006 04:20 PM
painting bottom?
Sorry but I have a stupid question. How do you spray the bottom of the boat when it is sitting on jack stands? I am planning on using ale craft 2000 on the entire boat.
madbouyz 05-05-2006 09:44 AM
Re: painting bottom?
If it was me , I'd put the boat on two 8' long 4X4's (or something else appropriate) standing on cinder blocks. That way you can roll it on one side at a time . Seems that unless the boat is hanging by lifting eyes you will only be able to do one side at a time .
Catagory5 05-06-2006 07:07 AM
You can block it on a side, paint one side to the keel then block it on it's other side and blend it along the keel. Or drain everything and roll the boat over.
I aasume your spraying the Awlcraft and you want a nice shiney finish and your not talking about antifouling "bottom paint"
Gmoney52 05-07-2006 10:51 PM
How big is this boat and what facilities do you have access to? I have always had the bow lifted on a stand( which was moved to paint and quickly placed back under with 1/2inch off the stand and the rear was chocked as far back as possible (stop painting a foot away from the stands) and wasn't painted until the next day when the chocks were moved forward so it could be blended. The AwlCraft is good for that.
