-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Bulkhead/body structural help needed (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/171613-bulkhead-body-structural-help-needed.html)
beamog 10-22-2007 10:14 AM
http://www.offshoreonly.com/forums/s...d.php?t=171586
This is a link to athread I posted in the Powerquest section about cracking of the bulkhead area. I figured this forum might get more attention. Please check out the link about the extent of damage to the bulkhead. Thanks in advance
Audiofn 10-22-2007 08:30 PM
I think that I would pass on the boat unless you can get a killer deal on it.
Jon
excalibur32 10-23-2007 09:16 AM
Hammer the dude and get a killer deal.
Jigsaw89 10-23-2007 05:38 PM
I agree with Jon. Don't be afraid to pass on this boat unless it's a super sweet bargain.
Jon
LAKESIDE RESTORATIONS 10-24-2007 07:17 AM
Jigsaws idea may not be that bad.. :)
The glass is fixable, but it is what you cant see. The unknown if you will that would or could be the bigger problem. If it is from a weak frame or rot then it can be a big expensive ordeal. That can make even a screaming deal end up being still an expensive ride, also dont forget about down time in having it fixed..
If you still are thinking about buying it, I would have it professionally checked to get an idea of if there may be more extensive damage inside.. :) Jamie / Lakeside
beamog 10-24-2007 01:05 PM
Thanks guys. I'm giving up on that one... I can do most if not all the work myself, but I rather be using the boat next summer than working on it.
Jigsaw89 10-24-2007 05:14 PM
Wise decision...
