Engine Painting
What is the best approach, if there is one, to painting an engine? Specifically paint the pieces individually then assemble or assemble the parts of the engine that are to be painted and then paint the assembly. Reasons forthe best approach is of interest as well.
once all together. this usually helps with chiping due to torqueing and such. it also helps aleviate and scratching or getting paint on mating surfaces that end up needing to be cleaned .
3 Attachment(s)
I usually assemble the basic engine components, then paint the brackets, pulleys, etc, individually to avoid chipping and such.
I painted this SBC the other day : |
Donman, I was about to poke fun at how you painted the spark plugs and oil filter too :D but instead I'm curious about that color. I know all monitors are different, but what is that? I have visions of orange motors in a silver bilge for my boat.
Thanks. |
Donman,
Very nice. How and what do you use to final degrease prep the engine before painting? What kind of paint did you use on that engine? |
3 Attachment(s)
here's a set done with IMRON.
Cool!
How and what do you use to final degrease prep the engine before painting? |
1- wash with degreeser
2-sand or debur 3-wash using metal prep or equivalant 4-prime using self etching primer 5-prime using epoxy primer 6-scuff using red scuff pad 7-paint using imron single stage or house of colors 3 stage for metalic and pearl colors |
Wow, that is one good quality paint job!!!!!!!!
Thanks |
Originally Posted by monstaaa
(Post 2345280)
cool,, just for for being attentive i'll pay special attenetion to th e job around yur rim ;)
(Post 2345043)
Then shoot the color over that. I didnt know you could get Imron in metalics. |
with out doubt. also clear.
3 Attachment(s)
1 Attachment(s)
Totally powdercoated:cool-smiley-011:
Basecoat clear, after acid etching primer and epoxy primer.
1 Attachment(s)
damn pics
house of colors has a vast selection of vibrant colors. although more involved to spray due to being a 3 stage system if trying to match say the boats colors or graphics its also a choice.
(Post 2350297)
Imron can be mixed to any color, metallics etc. Dupont has come out with their own house of color line.
Originally Posted by excalibur32
(Post 2351237)
It is Dupont, It's started as commercial/ aircraft paint been around like 30/40 years. two part single stage polyurethane.
| All times are GMT -5. The time now is 07:59 PM. |
