-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   PPG dbc vs. dbu (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/194838-ppg-dbc-vs-dbu.html)
caybraca 09-07-2008 08:41 PM
PPG dbc vs. dbu
What is the difference between dbc and dbu?
Also what is the differance between DP401LF and DP402LF
Epoxy Primer Catalyst?
glassdave 09-08-2008 11:21 AM
DBC is PPG's earliest OEM mathcing system and is a bit outdated with a reactive reducer, DBC is their second effort OEM system. Both are great but DBC is more user friendly and uses a straight reducer and eliminates one product from the shelf. Both give pretty much the same results but i stick with DBC.
The DP401LF requires an induction time of about a half hour before the primer can be sprayed and has a long pot file (i think like 24 or 48 hours or something) the DP402LF is for impatient people (like me :D) that want to mix an spray with no waiting but has a much shorter pot life (like a few hours) both give pretty much the same results.
caybraca 09-08-2008 02:19 PM
Thanks alot dave,but you refferd to both as dbc witch is witch. Thanks for your help.
glassdave 09-08-2008 08:51 PM
oops . . . DBU is PPG's earliest OEM system. and so on . . sorry bout that :cool:
customtouch 09-09-2008 12:05 AM
You might try wearing your respirator a little more often!!!!:evilb::evilb::evilb::D
glassdave 09-09-2008 10:37 AM
lol . . . . :drink: . . . bzzzzzzzzzzz
offshoredrillin 09-09-2008 08:19 PM
assclown? :evilb::grinser010:
DesertRage 09-11-2008 03:43 PM
PPG's P-pages (instruction sheets) say DP401LF will have as much as 50% better adhesion than the faster DP402LF especially on bare metal.
Dave, Do you buy into this? I used to shoot DP402 before it was replaced with the Lead Free product and had great results. Since the introduction of LF I have been using DP401LF hoping for the best possible grip.
Jon
glassdave 09-11-2008 05:04 PM
yes i would believe that for bare metal but doubt it is that much for gel coat. I only use the DP primers to spot prime and cover repairs on white gel. The only time i prime or seal completely is a full color change and have never had an adhesion problem. I use both 401 and 402 and lean toward 401 for the most part but do like to keep 402 on hand as well.
