hull modification
Has anybody heard of someone modifying boat hull .For example adding a step a none step boat.Or something other then just a blue print to the bottom.I'm just curious how good a secondary bond would last under severe water pressure and pounding.
It depends on who does it, how it is done, where it is placed etc... Also the materials used would be important. Epoxy would be a good way to go because of the strength. I have done a lot of hull work. I will say that it is not terribly uncommon for people to want to straighten the bottom (blue print the hull). However adding in a set of steps afterward is not very common. Also if they are added in the wrong spot it can be bad. Beyond that adding steps will also change the handling, turning & stopping attitude of the boat.. ;)
Just out of curiosity what hull are you thinking of messing with? :) Jamie |
i didn't have a hull in mind but had a discussion if the secondary bond on fiberglass would be strong enough to last.How do the racers do it?.Do they lay up a new hull every time they want to change there combo.I would think the would be constantly tweaking the hull design to stay out front.
2 Attachment(s)
The old Lucas Oil SuperV started out life as a non step Scarab. They added steps and, as i was told by one of the crew members, the running surface was left in tact under it all. It could be completely ground back off if it didnt work out. Not sure how valid the story is but thats what i was told at the worlds several years ago.
Not sure if these are steps or what but they were being added to a big azz sport fish. Saw them in the lot where we had the race boat at in Ocean City MD but couldnt find anyone to give me any details. |
(Post 2907228)
3 Attachment(s)
Originally Posted by fuelcustoms
(Post 2907479)
That interesting I would be very interested how it held up.If it held up I'm surprised you do no not here more people doing mods.It probably a case of not having enough balls on the chance it did not work :eek:
I think your probably right, time and the risk of it not working probably keep most from moding boats. I would imagine it was more common in the earliest days of the sport when you had to make your own speed though. |
| All times are GMT -5. The time now is 09:15 AM. |
