Here are two supplier's on line for 1700 D/B 45/45 with a no chop back and one is a wee bit higher then the other http://www.mertons.com http://stores.infinityfrp.com/StoreFront.bok and when you go into Metron's click on fiberglass reinforcements go into there 12oz double Bias Cloth which will give you prices on both 17oz and 12 oz and on the infinity site scroll down to the fiberglass section and go to knitted and biaxial . I often buy products from Mich fiberglass supply which give good prices if you buy glass by the roll but in your case if you are only buying by the yard i would recomend the two other sites that i have listed .
glass cloth
Dave what is the suppliers name ect. I have had no luck yet. Thanks JOHN
ttt
From Dave:
you can get the 1700 here, not sure why its so hard to find but no one seems to carry it. You'd think with as much as places push epoxy they would stock it, especialy us comp. http://store.raka.com/biaxial1700-17...x-45x38in.aspx |
web site does not come up.What is th actual name of the place. Thanks JOHN
search 1700 in upper right and it will bring up the stuff... seems to be a small problem with their website right now... i just tried that link again and it timed out. It's a good link though... I just purchased some. I can't wait to try it out as I've been using 1708 and really going through the resin. I use US composites 635 slow cure (non-blushing). Never tried west systems... too expensive for my blood. |
Originally Posted by Fenderjack
(Post 3099080)
Originally Posted by jackhammer
(Post 3099272)
| All times are GMT -5. The time now is 11:37 PM. |
