-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Guide Coat (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/240308-guide-coat.html)
J-Bonz 10-05-2010 09:59 PM
Guide Coat
Curious to here what others have used.... I purchased this stuff to give it a try but I am not to keen on it. It is very difficult to clean up..
http://www.autobodytoolmart.com/3m-d...1-p-11157.aspx
So, if i use a spray paint product... as I listed below, for the valleys were the paint is left how do I prep to put a layer of epoxy fairing compound...? Do I still roughly sand it to make it rough and then apply???
http://www.autobodytoolmart.com/sem-...3-p-15977.aspx
Whats worked best for the others??????????
Steve 1 10-05-2010 10:15 PM
I have used the 3-M Dry guide coat before and it worked ok,I use tool makers layout dye, cut 4:1 with acetone and sprayed on,Yes you need to clean up what is left in the hollows,Why ever take a chance?
J-Bonz 10-05-2010 10:47 PM
Any pointers on using the 3-M Dry guide coat??
"Yes you need to clean up what is left in the hollows,Why ever take a chance?"
Thats what I though.... :)
Steve 1 10-05-2010 10:58 PM
The surface should be clean and dry, I always clean with the shop magic universal solvent Acetone and wipe the 3-M one direction or pat on.It is a good product been around for a while.
cabana1 10-05-2010 11:11 PM
i use any old toner we have laying around the shop. Just reduce it down and shoot
mptrimshop 10-06-2010 12:18 AM
spray paint....whatever is on sale....wipe what is left on off with thinner....easy and cheap
Audiofn 10-06-2010 06:29 PM
I have always just used Krylon in a contrasting color.
J-Bonz 10-06-2010 09:16 PM
Am I an Idiot, I was trying to use the dry coat while I was still cutting down some roughed up area with 40 grit??
Steve 1 10-06-2010 09:31 PM
You can use anything for a guide coat with heavy paper,But
Using the fine paper we sand to 2000 and better, you need a guide coat that will not clog that paper, we also sand dry with silicon carbide paper.
J-Bonz 10-06-2010 09:40 PM
Wow dude, your outta hand.... I feel like the sanford and son of body work............ :) Thanks for the pointers
