Molding steps for dash
2 Attachment(s)
Ok, I've had trouble before getting up to the bow... I'm not as young and agile as I used to be so I need some better steps added in.
What I'm thinking about now is cutting the glove box out and starting over from the ground up. I would first use cardboard to mock up the whole construct, then make it out of wood for strength and glass over it. If I don't cut the glovebox out then the steps would go too deep between the seats. Anyone have cool ideas how to implement this feature? |
Originally Posted by jackhammer
(Post 3251901)
What I'm thinking about now is cutting the glove box out and starting over from the ground up. I would first use cardboard to mock up the whole construct, then make it out of wood for strength and glass over it. If I don't cut the glovebox out then the steps would go too deep between the seats. Anyone have cool ideas how to implement this feature? Personally I find the best solution is to keep an early 20's girl on board. I generally anchor at the helm, hand her the rope and have her tie it off to the front cleat... |
I like the way you think!
I could easily incorporate something like this... http://www.bustin-usa.com/products/t...flipupStep.php |
What about steps molded into the cabin door such as a Cig has?
The flip-down steps like you see on the back of firetrucks might work too.
| All times are GMT -5. The time now is 12:42 AM. |
