-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   linex on outdrive (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/253838-linex-outdrive.html)
BRET 05-18-2011 09:40 AM
linex on outdrive
So,
Got a lower unit that has to be painted. It is stripped to bare metal and was wondering if LINEX will hold up on a lower unit. Linex shop says yes, but has anybody done this? Did it hold up?
Boat will do 80 so I'm wondering if it will flake off eventually.
Thanks,
Bret
Knot 4 Me 05-18-2011 12:35 PM
Not sure you want the thickness build-up and not sure how hydrodynamic the finish would be.
CigDaze 05-18-2011 01:05 PM
Linex?...the same textured and gritty linex that's used in pickup truck beds? Why would you want to do that?
RT930turbo 05-18-2011 03:43 PM
Checked out their website, it looks like they have all kinds of different coatings.
http://www.linex.com/pages/2010/mili...3350_blast.php
Maybe this will help keep bravo's together :cool-smiley-011:
Catastrophe 05-18-2011 03:50 PM
It wont help keep anything together........and it will be a b itch to take off.
Airpacker 05-18-2011 05:39 PM
AND HOW!!!!!!!!!!!!!!
mlb75 05-18-2011 07:45 PM
yea not sure what the advantage would be of using this. If you used the normal truck bed liner it would be a huge mistake since that would just increase drag and hold in heat. If you're looking to leave the boat in the water and want protection from corrosion etc then use a good bottom paint. If you're like most of us and trailer then any paint will do. IMHO though stay away from any high build coating.
fasttoys7619 05-18-2011 09:41 PM
I painted my lowers with gloss black rattle can, Plasticote brand, holding up very well
Thunderstruck27 05-23-2011 01:43 PM
Originally Posted by BRET (Post 3406362)
So,
Thanks,
Bret
Why are you thinking about using Linex?
