strong adhesive/epoxy
need a good strong but liquid adhesive/epoxy thanks Rob
These are what I use:
Two part epoxy-different set times and rigid Gorilla Glue- caution of excess glue expanding when drying Liquid nail-rigid wood connections 3m 5200- the marine standard |
used 5200 on this before, but did not flow down far enough and failed after a while...so needs to be pretty liquid
There is a huge fiberglass place local to my in the Tampa Bay area, called Fiberglass Coatings. http://www.fgci.com/
They are super helpful and knowledgeable, i would just call them and explain application. I am sure they will sell whatever you need and maybe you can get it locally if you don't want to ship it. |
If you are looking for a two part epoxy look at MAS Epoxies based in NJ.
what are you trying to bond? Remember epoxy requires a roughed up surface for proper mechanical bond. If you just trying to run down into a void the best you can hope for are the fill properties with little actual adheasion.
| All times are GMT -5. The time now is 12:10 PM. |
