-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Need to attach something to the inside hull (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/275290-need-attach-something-inside-hull.html)
pluguglyinhere 04-26-2012 05:50 PM
I am recarpeting my 97 Scarab 22. I took about a two foot tall section of carpet off the sides of the interior. I kinda figured that there was not much material between the inside and outside of the boat on the sides.
I was hoping to attach a nice small cargo net bag on each side for wallets and things but how. Is it safe to adhesive a peice of wood the side of the boat, cover with carpet so I can screw to it?
glassdave 04-26-2012 07:37 PM
yep, no prob. About the worst that can happen is it could print through but its highly unlikely at that depth.
pluguglyinhere 04-26-2012 08:35 PM
Thanks Glassdave, do you recomend an adhesive? I assume by print through you are talking about a shadow or the adhesive bleeding?
glassdave 04-26-2012 08:56 PM
I would use a mix of epoxy and west systems 404 to a thick paste, not a bad idea to put a layer of glass over either. Print through is when you can see the shape of coring or laminates in the outer skin, it is usually a function of different rates of thermal expansion/contraction. Its nothing structural and the thinner the more susceptible the laminate, I doubt you will have any issues though.
