K-Plane thru-hull fitting removal
Thought I would post this here too since many here would be dealing with this.
Are the thru-hull fittings for the hydraulic lines pressed in or threaded? I put a little heat to mine and leaned on it pretty good with a pipe wrench and it didn't budge. Don't want to get any more aggressive if it's pressed in. http://i149.photobucket.com/albums/s...a/101_2125.jpg |
Mine were threaded in.
Curious, why are you needing to remove? Can you leave it as is?
They should be threaded. Mine were, 3/4 inch rough thread if I recall.
Mine are threaded. Just had them out last week. They get corrosion from dissimilar metals. Stainless into aluminum. If the don't come out with a little heat and penetrant I would leave them in.
Originally Posted by Holy Smokes
(Post 3675497)
| All times are GMT -5. The time now is 11:58 AM. |
