-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   balsa coring (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/277754-balsa-coring.html)
captrod28 06-01-2012 05:51 PM
balsa coring
I have just removed some wet balsa coring from my cabin interior. I purchased some replacement balsa coring. Can I use some construction adhesive to adhere it to the under side of the top deck and then glass it over, or do I need to mix some resin and thicken it and use this as a mastic? It is a patch about 4ftx 4 ft.
glassdave 06-01-2012 09:39 PM
You would be better off using something like ATC's corebond but I don't think it comes in anything smaller then five gallons. Do not use any type of construction adhesive balsa needs to be bedded in to either a layer of ounce and a half mat and resin or a bedding compound. It's tricky and not impossible but that's a pretty good size piece of core. You might be able to whip up a good thick paste using some resin and west systems 404 but that would be my last choice over traditional methods.
Glassic R.T. 06-05-2012 06:57 PM
Captrod28 ,there have been way to many horror stories out there from using construction adhesive like P/L , for re-coring , transoms , stringers , etc ................
dereknkathy 06-12-2012 09:22 PM
doing glass work over your head is not pleasant. redoing the job because you used gorilla glue is much less pleasant...
c_deezy 06-13-2012 12:11 AM
What is the working time with corebond before it starts to cure? Is it a two-part system?
If you had a decent working time, you could prep things and vacuum bag the core so that you wouldn't have any voids behind it. I don't think I would do the whole 4x4 area at once tho, probably split it into two sections of 2x4 or 2x2 depending on working time.
glassdave 06-13-2012 07:23 AM
Corebond has a half hour to forty five minute work time pending temp. It works quite easy and is pretty forgiving. It works well in applications like this but the biggest problem is i dont believe it comes in less then five gallon altitudes. I buy it in bulk and would be happy to split off a qt or so at cost if need be, it really is a great product for bonding upside down.
Bagging would be nice but its almost impossible to get a seal on an old core. Its actually not as bad as it seems. I have done areas as large as five foot by six foot by myself in a single layup. Technique is everything when working up side down wet on wet.
