-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Vinyl-ester work time (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/297466-vinyl-ester-work-time.html)
JRider 06-03-2013 07:51 AM
How much work time before vinyl-ester starts to kick?
Unlimited jd 06-03-2013 09:30 AM
Depends on temp, humidity and catalyst ratio. Can be 10 minutes to several hours
c_deezy 06-03-2013 09:36 AM
+1. Different batches have different kick times too and quantity will effect it also. If you mix up say 30 oz in a quart cup it will go off quicker than 30 oz in a 2.5 qt cup or if you pour it in a paint tray. Large quantity in a smaller container will go off quick.
Too many factors to give a specific time.
JRider 06-03-2013 11:23 AM
What does higher humidity do? Cure faster or slower?
FIXX 06-03-2013 03:16 PM
when all weight out properly with the mek i averive between 30 to 45 min before it starts to gel up..
glassdave 06-03-2013 06:11 PM
yep, a good quality VE at aproz 70 degrees will give 30-40 min. I would think higher humidity would speed it up a bit though.
