correct paint
Hi everyone,looking for advice what type of paint i should use on speed boat i bought as a project.Will be going thru the whole boat as far engine trans and drive boat is Magnum Marine 27ft,so question here is what paint should be used to paint the whole boat because the boat will be 70+ mph and i'm worried about the bottom how it's going to hold.Thank's everyone in advance!
Originally Posted by Thunder 2013
(Post 4010730)
thank you,will look it up
Gel coat
Not sure how a gelcoat will hold over the old gelcoat,besides i i bought a 33 years old speed boat as a project and side has been painted originally from manifacturer and still shines like new,but not the gelcoat.So i think paint will require less maintanence as far as buffing and waxing!
Gelcoat on the running surface (bottom) and paint on the deck and sides.
What procedure i have to follow to re gel coat the bottom
Im going to be redoing the bottom of my boat this winter and thought about using the interlux VC performance epoxy... any thoughts about that?
Originally Posted by chrisf695
(Post 4013739)
I have not look at interlux vc yet,as i am still thinking what should i use paint or gelcoat?the problem if i decide to re gelcoat is that i have to flip the boat and i really don't feel like doing this.let me know how it is after you done with the paint job!
| All times are GMT -5. The time now is 08:00 PM. |
