replacing main stringer and transom
I have had three Scarabs and all were done exactly like that. Build quality after 88 was pretty good with the brand but it is just some major oversights like this that come back to haunt them. My 38 Thunder is the same way and will need new everything and some re designing along the way. Actual layup is good for a production boat for that time. Keep the pics coming, Dave will take care of ya he's been doing this a long time . . . .
08 OPA High Points Champion
My 89 Scarab III had the exhaust exits molded into the swim platform. The exits sat just above the waterline. the 5in exhaust tips were installed and sealed from the inside. this left the outside to soak up any water that would eventually make its way between the exhaust tip and cut out. That's an obvious "7 P's" right there (Piss Poor Planning Provides Piss Poor Performance). It did make it 23 years though before I gutted it and rebuilt the bilge.
[ATTACH=CONFIG]540549[/ATTACH][ATTACH=CONFIG]540550[/ATTACH]
ramos45...my scarab was the same,,,had that funky exhaust going thru swim platform...some one applied ,,i guess 5200 all over covering existing hole and nothing more from the outside, but then added a plate on inside. but transom was real nice and dry rotted all around there..
i am not sure what i am going to do better exactly...hard to get up in there and do anything. i honestly wish my scarab didnt have that gay looking swim platform.
did u close urs off on the outside some how?????
flash..............out
I completely sealed them off. From the inside my new transom wood closed the holes then from the outside I filled in with cabosil thickened resin. If I were to do it again I would make a plug from wood the closest thickness of the remaining void. I now have some cracking in the paint in the circle pattern of the old holes. I ditched the platform and got a new aluminum platform. I liked the old one, it matched the boat and made the it look more sleek but it does have its drawbacks in design.
Forgot to mention, I also ditched the stock exhaust design and went to 4 4" holes straight out the back.
u got any other photos of ur scarab 3.........as i had one also...looks like u have some graphics going there...like to see better...........
flash ....out
haha.like the 7 P's........also like the KISS theory...KEEP IT SIMPLE STUPID
