Transom replacement
I have a 1998 353 Fastech. The transom is rotted in it. The formula boats has a lay support it looks like that goes up the back part way . Can that be cut out or does it have to stay? Has any one replace the transom in a Fastech and do you have any suggestions?
I have done a few transoms on my Formulas. Mine are older. I had to cut everything about 8 inches from the transom. Thats the only way to make enough room to get the new plywood in. I bet you will have to cut it, then replace it later on.
Is your bilge the one with the whole fiberglass innerliner deal?? If so talk to glassdave, he has one of those apart right now...
A new transom comes under the category of " nothing money won't fix". I have done it twice.
Originally Posted by 1stFormula
(Post 4399368)
Thanks for all the input. Does not look like it is going to be an easy one.
1st Formula Any idea why it went bad and what made you realize it was. I have a 98 as well and want to check it out. Have done a ton of work so far and the transom is one thing I worry about although it seems solid.
Where is the rot and how do you know it is rotten? I would do a thorough drill test to see the extent of the rot. I watched a former member named borgie cut his whole transom up and it looked pretty damn solid to me.
So sorry for just now getting back. We think It started where the exhaust went threw the starboard side. I have taken the thunder box off of it. I am convinced that was the issue.
It was very bad. It had to be completely rebuilt. They said it was one of the worst they have seen.
| All times are GMT -5. The time now is 04:42 PM. |
