Compound and Wax
Have a painted boat that needs to be detailed. Paint is a single stage about 6 or 7 years old. Need a good medium compound and a good wax that will work well on a boat. What's everyone using?
Thanks |
Go to an auto body supply shop .... Talk to them or bring the boat. They will be able to steer you in the right direction. It's not just about the right product... It's how you do the job. Without a good coach your gonna do a lot of damage. If you have any doubt it WAY cheaper to pay someone to do it than to mess it up and get it repaired.
http://www.fountainofyouthrestore.com/tbuff.html
love this stuff on single stage . . . . followed by Vitreo |
(Post 4401896)
love this stuff on single stage . . . . followed by Vitreo Hand or buffer and what pad? Tks |
(Post 4401896)
Originally Posted by f_inscreenname
(Post 4402060)
Says it will remove 8 and 400 scratches. Mine don't have 400 grit scratches but is a bit dull. Is it that good?
Hand or buffer and what pad? Tks if its weathered single stage i still like Totally Buff with a wool pad, and its the only time i use wool on paint to. You can follow it with something finer like 3M's 6064 and foam then Vitreo. I've got a ten year old Imron job on a Skater in the shop that TotallyBuff compound is doing an amazing job on, you can work tough old single stage jobs like gelcoat.
Originally Posted by frickstyle
(Post 4402071)
Dave, what do you suggest for newer paint like mine that just needs a quick rub-out and then some protection before it hits the water?
OK, we'll figure something out then. There is some overspray on it from the transom re-rig. We'll need to cut that down/off.
Thanks Dave.
mark,, solid color or metallic ? no compound will take out 400 scratch's
Solid White. Just looking for a gloss of some kind.
| All times are GMT -5. The time now is 03:10 AM. |
