-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Cleaning bilge anything else??? (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/335683-cleaning-bilge-anything-else.html)
TruxtonFox 03-21-2016 10:22 AM
I currently have the motor out of my 77 scarab. I had a little mold and grime down in the bottom that I have since removed and cleaned. Solid stringers and transom, is there anything else I need to do while Im down there to prevent damage etc. I was going to reseal the drain holes and maybe put a fresh coat of paint on it, but other than that im ignorant on what else it may need. Thanks
F-2 Speedy 03-21-2016 10:25 AM
Id replace the bilge pump while its out
TruxtonFox 03-21-2016 10:32 AM
Ya, I replaced the pump and auto-switch when I took them out, also added a blower for the port engine, guy only had one in the boat before.
sprink58 03-21-2016 03:03 PM
Think about ANYTHING you can't get to after the engines are back in....if it's even the least bit suspect...replace it !!
neva satisfied 03-21-2016 07:06 PM
I would install an electric oil change pump. It will make your services much easier and faster.
TruxtonFox 03-21-2016 07:44 PM
Thanks for the tip, I will definitely look into that oil change system, I'm thinking about painting the bottom white as opposed to the old grey, any input on types of paint that are better than others
3pointstar 03-22-2016 05:51 AM
I not famular with an oil change pump but I've used the hose system that attaches to the oil pan and can be thread thru the drain plug. In fact the hose has the drain plug attached. Draining oil after the engine is wam take a few minutes with no mess.
While I'm sure a pump works great. Gravity won't breakdown
3pointstar
hoodoo 04-03-2016 07:35 PM
I'd take a hard look at the thru hulls for your raw water pick ups while their easy to get to.
