-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Sandblasting (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/347391-sandblasting.html)
Cobaltjoe 06-04-2017 11:30 PM
Sandblasting
My boat was painted with some type of car paint and is starting to peel so I want to sand it and re gelcoat it. Does anybody know if I can sandblast the paint off? Will it hurt to gelcoat underneath?
phragle 06-04-2017 11:53 PM
you have no idea what you are getting into.... just sand it and repaint it.
Cobaltjoe 06-05-2017 12:42 AM
your right, I've never sandblasted anything... Have already begun sanding. Just wondering if there's a faster way
dunnitagain 06-06-2017 08:39 PM
Yes there is a faster way , Plastic Media Blasting , works great on paint over fiberglass . Fast and Smooth
Cobaltjoe 06-06-2017 10:52 PM
really, I haven't heard of that. I will do some research. Thanks alot.
Padraig 06-07-2017 06:45 AM
I am not sure how well it works on painted boats but make sure you have an experienced, skilled operator. It is not something that you learn in a few minutes a bad operator can really screw metal parts up, imagine what can happen to gell Coat and fiberglass. Also, you do not want your boat to be the first boat he does.
Padraig
dunnitagain 06-07-2017 07:11 AM
Padraig
Your exactly right , When I blast , the pressure is only 36-38 Psi . I use 12-16 Urea plastic . The plastic leaves very little profile , its very common to blast Corvettes to restore . I cant post pics but , just finished the bilges of a 33Eliminator and a 26 eliminator that had that horrible
multi colored splatter paint with the Ivory Base color . Also a Hawaiian Jet boat with 5!!! different layers of paint and primer and a Hydrostream Vulture for myself . I also blast bodies and chassis for some of the napcar teams .
Where are you located ? I could do it for you if your willing to drive.
