-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   hull wax (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/351489-hull-wax.html)
steve00 12-27-2017 05:41 AM
hull wax
Hi all, well not sure between fresh water and salt but is there a good hull wax for below the waterline that stays on without having to reapply to often , thanks.
t500hps 12-27-2017 07:16 AM
No idea. I'm probably one of the few that occasionally applies wax to the bottom. I do it because it makes a huge difference in how fast the bottom turns brown in our sediment filled rivers. I've never been "scientific" enough to test if one last longer than another.
steve00 12-27-2017 07:38 AM
ok thanks but who's wax are you using .
Tahoe540 12-27-2017 09:03 AM
2 Attachment(s)
I also detail and wax the bottom of my boat. As far as type of wax I would use a pro product Like Adams, Chemical Brothers and others that have online shops to order from. I use a polymer type wax over a carnuba type for the bottom and use a machine. Really looks nice on the trailer.
3pointstar 12-27-2017 08:06 PM
We have had somewhat the same issue with the brown stains. Rather than try to keep wax on and spend hours doing that we have used a solution of Iron Out. Spray it on and rinse off it is a very easy process and the results are remarkable
all the best
3pointstar
