-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Stringers and transom replacment on kevlar hull (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/360640-stringers-transom-replacment-kevlar-hull.html)
St.clair85 05-15-2019 10:58 AM
Hello guys i am in the process of restoring an old kevlar 31 excalibur. Its not in the shape the seller claimed but i like the boat and it has lots of potential for what i want to use it for. My question is if i were to redo the stringers, bulkheads an transom which materials can i use with the kevlar hull? Do i need to stay kevlar 49? I have done transoms an stringers and that before but never on a hull like this. Any insite or ideas would help thanks
St.clair85 07-11-2019 11:13 PM
Bump. Never worked with a kevlar hulled boat before. Top deck seems to be glass and has a foam core in some places and hull has no core that i can see just plywood transom and stringers ect. Anyone know for sure the layup of these boats?
Griff 07-12-2019 12:32 AM
Anything that works with fiberglass will work with kevlar.
Jimofstuartfl 07-14-2019 08:39 AM
The hull was Kevlar. The stringers were probably not. Just grind and glass them.
St.clair85 07-21-2019 07:44 PM
Ok great thanks for the info. Got a good deal on bravos so i am converting from trs while im redoing the transom and stringers.
Team Archer 07-27-2019 12:01 PM
I would make sure you only use vinylester so that you get a good bond.
